Ir para o conteúdo principal
Repair information for a variety of old school gaming systems.
106 Perguntas Visualizar todos
Why does my NES display a solid pink when it is turned on?
When I start up my NES system every time, it displays a solid pink. Does anyone know why it displays pink? The pink screen is annoying me. I've already tried using my air pump to try to get dust out of the console and also I keep trying to reset the console.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
If you insert your game, and the screen is pink or any other color. Follow these steps to the letter.1. Blow into your game cartridge, and NES system slot with a dry mouth. Slide your game in. 3. Start pressing the reset button,but at the same time push down your game. I had this exact same problem, and solution. Hope this helps
Esta resposta foi útil?
Pontuação 2
1 comentário:
thank you so much. i got my tetris working because of you.
por
NES pin connecter compatability
Clean the 72 pin connector, this should help.  You may also need to clean the cartridge connector if it is isolated to the one cartridge.  Alternatively replace the 72 pin connector (ebay).  I recommend cleaning first to save cash.
Update (11/16/2018)
Why won't the screen and red light stopping blinking?
Pontuação 1
1 comentário:
I tried cleaning it numerous times now (just now got the stuff to clean the NES so that's why I'm replying just now), however the only game it worked with 100% (no glitches or magenta screen) is Super Mario Bros/Duck Hunt. Before I buy a 72 pin connector, would you suggest other solutions or possible problems?
por
Adicionar a sua resposta
Aiden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 90
Duração total: 5,518
