Facing Problem on my calculator
My calculator is fully reversed. The number is reversed. Everything is rotated into 90 degree. How can i fix this problem?
Esta é uma boa pergunta?
If you have not tried the reset sequence here it is…
(CLR)
(Setup)
(Yes)
Esta resposta foi útil?
No.Still it's not working.I already did this work.My full calculator screen is reversed.
How's it going I'd like to try to help you fix your device so there's not a factory reset button on the back of it but you could try hitting shift 9 to enter the list then press 3 to reset all and then the equal sign to confirm it then hit the AC button to return it to normal then shift AC to turn it off reboot it see if it works like that then if that doesn't work you may try to take out the battery and getting a paperclip so the positive and negative terminals can reach each other that will help take out some extra electricity let it sit for 5 minutes then replace your battery
This actually worked for me.. I took of the battery after resetting all and Voila!! it normalized. Thank you for this.
Hopefully that will help if not please let me know and I will be happy to continue finding things to help you out
It is not working
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 48
Ao todo: 9,882
6 comentários
20°56°its answer plz solve
por Zarmeen Alishba
shift button is working only for offing the calculator not for other usages…
por mukesh
Has anyone encountered getting the wrong answers when there is a logarithm? Tried to on and off at first and worked but it doesn't work now, also tried resetting but it didn't help.
por Anfernee Jinang
@Anfernee Jinang When you have different symptoms you should ask a new question rather than posting as a comment under an existing question.
por tcagle53
Also there are only 3 modes left and the rest of the modes just got vanished.
Shift+7 Function is also not working any more.
Please help me
por Ansir Bukhari
Exibir mais 1 comentário
