Ir para o conteúdo principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Perguntas Visualizar todos
Can I repair broken IR and Fan connectors - sheered off at logic board
I have a Mac mini mid-2011. I installed an SSD as the second drive.
It works but I have broken the IR and Fan connectors - sheered them off at the logic board.
Is it possible to repair these two connectors with “micro-soldering”?
What tools do I need to do that please?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@cooker47 that will depend on how they are broken and if they destroyed the solder pads. If so, you will most likely have to run some jumper. There are no schematics or boardview for the Mac Mini so that would mean it could get tough. If the pad are still decent, you can resolder the connectors (or buy new ones if the originals are destroyed). Take a look at the answer I popped off the fan connection from the logic board...Fix? and see how to solder it. Different connector, same idea. Post some images of our damage so we can see what you see. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 3
I would directly solder wires to motherboard
Pontuação 1
Adicionar a sua resposta
Michael Cook será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 224
