Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
17" MacBook Pro Backlight Issue A1297
Hey everyone.
I have a mid 2010 MacBook Pro “17 A1297 with a backlight that isn’t working. I was working on the laptop when the backlight cut out.
Here is what I’ve done so far:
Reset SMC = Nothing
Plugged into an external display: Image is shown on the external display and the primary is shown in system preferences.
Tested Backlight Fuse: Backlight fuse has continuity.
'''Test for shorts: Tested for short circuit using the advice from No backlight, fuse blown? Works fine except backlight! A1398
Nothing looks wrong on the board and there isn’t anything obvious to me to suggest anything wrong.
Before I blow a lot of money I wanted to see what others would think of the situation!
Thanks so much!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If the backlight fuse is alright I personally would wean towards the screen being kaput or a wonky backlight pin. If it works fine with an external display that is also good news. Either there is a backlight pin issue or a screen issue.
Here is how you would repair the backlight pin
https://www.youtube.com/watch?v=HOhX95k-...
Here is how you would replace the screen (the only part condition is B stock)
MacBook Pro 17" Unibody (Early-Mid 2009) Display Assembly
MacBook Pro 17" Unibody Display Replacement
Imagem de Replace a display compatible with the early 2009 or mid 2009 model A1297 Unibody 17" MacBook Pro laptop. Part #661-5040. Includes the * 1920 x 1200 17" LCD Screen, Display Cover, Bezel, iSight Camera, Clutch Hinges, LED Assembly, Wi-Fi Antenna, Camera, Display Data Cables.
Produto
$239.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
As I expected. Such an odd thing to happen and so randomly.
Thank you so much for helping and also thanks for giving me more excuses to watch Louis Rossmann. Such an awsome guy.
por
@computerlord No worries! Happy I could help. Louis Rossman saves us computer users so much money and time and he is personally my favorite "celebrity repairman".
por
Adicionar a sua resposta
Josh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 2,869
