Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
cant insert disk in PS3
the console will not accept a disk into the slot, it seems like something is blocking the slot. another disk perhaps? how do i remove a stuck disk? or how can i determine what the issue is exactly?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @ohmwrecker ,
Try the Most Helpful Answer in this link to see if it works in ejecting a disc, if there is one that is.
My PS3 disc is stuck, how can I get it ejected?
If it doesn’t work then you may have to remove the drive and check if there is anything obviously in there or not.
Here’s a link to the ifixit PlayStation 3 Blu-ray Disc Drive Replacement guide which may be of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Robert Hart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 3,175
