Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
How to restore iPhone from recovery mode?
how to restore iphone from recovery mode
Esta é uma boa pergunta?
Pontuação 0
3 comentários
have you tried connecting to itunes and clicking on restore? or are you stuck in bootloop?
por
what error itunes giving when trying to restore?
por
thnk u so so much
por
Adicionar um comentário
6 respostas
Pergunta mais útil
just plug in the phone via usb cable and try to restore the phone but you must have a internet connection. restore need a software file (version=4.3.3) 660mb that will downloaded automatically . if you are stuck in the loop then remove the back cover and remove the battery plug for 5 mins then restore it .
Esta resposta foi útil?
Pontuação 1
1 comentário:
tried that , didn't work
por
can't restore in Itunes receive error message 1015
Pontuação 0
1 comentário:
that's a common error for a jailbroken device that apple won't recognise. Google the solutions for either mac or pc-should be straightforward.
por
Connecting to iTunes and click restore will erase all the data and setting on iPhone. If you don't have an available backup to restore from, you'd better not do that. The tool ReiBoot is used to exit iPhone recovery mode with one click, without resetting iPhone and connecting to iTunes. Have a try if needed.
Pontuação 0
You may try this iPhone Photo Recovery, which allows you to recover photos from iPhone directly, see a guide here:
how to recover deleted photos from iPhone 5
Pontuação 0
To get iPhone out of recovery mode, I'm afraid you'd turn to some professional software to help you. Or you can simply refer to the guidance here: iPhone Stuck in Recovery Mode & How to Fix
Pontuação 0
Here is a quick guick on how to fix iPhone stuck in recovery mode:
1. Lauch iTunes (make sure you've installed the latest iTunes).
2. connect iPhone to computer via usb cable.
3. Wait for iTunes to recognize your device. An iTunes popup will display that offers to restore your iPhone using your most recent backup.
4. Click OK to exit restore mode.
Pontuação 0
Adicionar a sua resposta
vinothini será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,655
