KitchenAid Dishwasher runs intermittently but doesn’t clean
Fills with water-wash cycle stops/starts for hours but not cleaning. Cancel-Drain works fine. I’ve replaced the sump and motor and the control board but still getting a 4-3 error, which is not showing up in any searches.
A lot comments mentioned the door actuator not making good contact with the door latch switch in this thread that describes the problem .
Whirlpool Dishwasher stops after filling with water
Model #KDTE104ESS4
Another clue-burnt wires leading to control board (disconnected during control board installation)
Update (11/08/2018)
Thanks for responding. Yes filter is clean.
I don’t think the sprayer arms are moving any water. The tub fills and sometimes sounds like it’s working but top rack not wet.
Esta é uma boa pergunta?
8 comentários
Did you check the float in the bottom right corner? If it’s stuck it won’t let the tub fill up properly.
por Matt
Yes float is functional.
por Curtis
When I replaced the control board I noticed the outside of the panel wires that go the control board look burnt. Should/can I replace those?
por Curtis
is the error definitely 4-3?
por Matt
Yes it’s 4-3.
por Curtis
Exibir mais 3 comentários
