Ir para o conteúdo principal
How to fix white screen of death on iPod Nano
so my iPod Nano has a white screen of death I Can’t play music and it is making beeping noises
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@stevejobs99
the white screen simply means that your iPod has a backlight. Since it has no video and the beeping, sounds like an issue with your logicboard. You will have to disassemble it using this guide iPod Nano 2nd Generation Logic Board Replacement and take a look at the board. Check for damaged looking components. There are no schematics available and they are a PITA to work on, so this will not be an easy repair.
Esta resposta foi útil?
Pontuação 3
6 comentários:
how do I take it apart if I have no screw drivers
por
@stevejobs99 there really isn’t a way do do this non-destructively if you don’t have the proper tools.
por
how do I fix it then
por
@stevejobs99 you can't fix what you do not know is broken. If you do not have the tools to open it up you will have to consider sending it to someone that may do it for you. Not a lot of places repair these because of the difficult working on it
por
From an economical perspective repairing this iPod might not be worth it. You can get an iPod in acceptable condition on Amazon for 30$. If you don’t want to spend the time to get this iPod repaired or try to DIY then you are better off getting one of these iPods used on Amazon or eBay.
por
Exibir mais 1 comentário
Adicionar a sua resposta
Steve Jobs Parody será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,125
