Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemaSamsung Television. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Television.
Can I fix this?
My tv will power on with a distorted pic and a loud static sound (even with vol off) then power off like it is resetting. It will eventually be alright until you change the input or turn off. When it first started it would do this for maybe a min or so. Now it will do this for over 30 mins.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Jules Ggirl  this will depend on the model of your TV. This could be a power supply or main board (most likely) issue. We need to know the model and need to know what you have checked.
Esta resposta foi útil?
Pontuação 2
Whether you can fix this TV depends on your knowledge of electronics… on your ability to solder but also to be able to remove components competently then replace them .
Their are high voltages generated inside a TV the primary side of a SMPSU (switch mode power supply) will kill even the experienced dabbler.
Pontuação 0
Adicionar a sua resposta
Jules Ggirl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 68
