Stripped screws on battery cover
Would this item IF145-118-1 be able to remove the srews for the battery cover on this device
Esta é uma boa pergunta?
Sure, there is a possibility those would work. If those fail to remove your stripped screws, you can use the guide below for more tricks on extracting stripped screws.
Esta resposta foi útil?
yes it should. It is your best bet next to a Dremel
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 370
