How do you change the transmission fluid in the Model S?
Has anyone looked into how to change the single gear transmission fluid in the Model S?
Esta é uma boa pergunta?
Stephen Leung this should help you out:
Gearbox Fluid - Front (Remove and Replace)
FRT No: 39300102
Special tool required for this procedure:
SupplierPart NumberDescriptionTesla1054946-00-AFluid Transfer Pan
Gearbox Fluid - Large Rear Drive Unit (Remove and Replace)
FRT No: 40300102
''Warning: If the vehicle has air suspension, activate "Jack" mode on the touchscreen before raising and supporting the vehicle.''
''Caution: Do not attempt to fill the drive unit through the upper plug.''
Toe link
Shock absorber
Esta resposta foi útil?
This is a guide on how to replace the transmission fluid for the S P85 model. I believe they’re all rather similar in terms of design.
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 33
Duração total: 4,510
2 comentários
What kind of oil should I pour into the Tesla model s differential
por peretiatkoaa
sorry for my english
por peretiatkoaa
