Ir para o conteúdo principal
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
20 Perguntas Visualizar todos
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
Esta resposta foi útil?
Pontuação 2
lens do not get back when on/off button is pressed.
Pontuação 2
1 comentário:
same answer as above :-)
por
make sure you are not holding the lens when you turn the camera on.
Pontuação 1
can you help for restart the camera
Pontuação 1
1 comentário:
Camera lens does not move when switch.
por
Adicionar a sua resposta
Pinky Kasotia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 25
Ao todo: 6,044
