Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Perguntas Visualizar todos
Can you test an LCD display to make sure its broken?
The phone was dropped and cracked the front screen. I can get a red light when it charges, and sometimes a blue light will appear but it looks like its pulsing very slowly. Apart from that it will not boot up at all.
Checked the battery with a multimeter and its seems fine, also the charging port sees to be doing its job OK.
Thank you in advance for any help you can give me :-)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
hi, yes you can, however to remove the chance of another part causing the issue you will need another device that is the same. Once you have done this, follow the replace screen guide until step 14 ( Samsung Galaxy S6 Screen Replacement )
then disconnect the screen ribbon, using the test display cable ( Galaxy S6 Edge/S6 Edge+/S7 Edge/Note5 Test Cable for Display Assembly ) check if the display works.
Imagem de Galaxy S6 Edge/S6 Edge+/S7 Edge/Note5 Test Cable for Display Assembly
Produto
$9.99
Esta resposta foi útil?
Pontuação 3
2 comentários:
Ahh, what a great idea. Now i just need to find another phone, its a shame it cannot be tested on its own...... Thank you so much for your help, this is such a great site :-)
por
no problem at all, If the screen wornt turn on then you will need another phone to test if the screen is dead, either thatr or a super cheap test screen from Ebay
por
Adicionar a sua resposta
Paul Allen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 311
