Ir para o conteúdo principal
The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
Plantronics Voyager Edge Blue Tooth
My Plantronics Edge turns off the blue tooth on my Samsung s9 when I make an out going call via OK Goggle, I have to go in to the phone and press the icon to reconnect it and then it is fine for that conversation only. Any suggestions? Glen. Thank you all.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @gbat ,
Check the advanced WiFi settings , especially “Keep WiFi on during sleep” (set to always) and see if this resolves the problem.
Go to Apps > Settings > Connections > WiFi > tap 3 vertical dots icon for more options > Advanced > Keep WiFi on during sleep
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your reply, I'll give it a try.
por
Adicionar a sua resposta
Glen Batten será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 151
