Ir para o conteúdo principal
The Motorola SLVR L7 features Bluetooth connectivity, a digital camera with 4x digital zoom and has a speakerphone.
Why is my phone powering off after turning it back on?
It's an old phone I haven't used it for awhile, but when I plugged it in to charge it says low battery then turns itself off. I left it to charge for awhile, came back, and the same thing happened when I tried to power it back on. Does this just mean I need a new battery or is there something else going on with the phone? (I tested the wire on another device and it works)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @rxzero ,
If the phone stays on when the charger is connected but not when the working only on the battery, then most probably the battery is failing to hold its’ charge and needs to be replaced.
Here’s a link to the ifixit Motorola Slvr L7 Battery Replacement guide, which may be of some help.
Replacement batteries are available online. Just search for Motorola SLVR L7 battery to get results for suppliers of the part.
Esta resposta foi útil?
Pontuação 1
Not an expert but my guess is that it might be a battery problem sorry if I get it wrong, My phone’s battery is slightly swollen and it does the same thing
Pontuação 0
Adicionar a sua resposta
Kathy D. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 346
