Ir para o conteúdo principal
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
68 Perguntas Visualizar todos
New screen not responding to touch/swipe
My phone fell and the screen broke and became unusable. I removed the old LCD assembly, then plugged a new assembly. When I turned on the phone, everything was displayed perfectly on the new screen and all the buttons worked. However, nothing happened when I tried to tap or swipe. I already returned that LCD assembly because I thought it was defective, but I just received a new one from a different vendor and I see the same issue. I suspect there’s something I should be doing with my phone. Please help! Thank you.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Forgot to say that the phone also restarts by itself when I turn it off and the new screen is plugged.
por
Adicionar um comentário
1 resposta
If a screen replacement doesn’t solve it it would be more likely be an issue with the motherboard. Replacing the motherboard should fix the issue. The teardown guide below should help you out a bit with replacing the mobo.
https://www.ebay.com/itm/OEM-CLARO-SAMSU...
https://www.youtube.com/watch?v=uIONMLkp...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Giuseppe Salvato será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 83
