Ir para o conteúdo principal
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 Perguntas Visualizar todos
Why no power on my n64?
I was sitting and playing on the n64 and then i tilted it up a little and the light went out.
and there is no power! Also i was testing the another clean system but i accidentally put the memory controller accessory into then ram pac port and now it wont show a picture!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I found out there is a rip somewhere in the cable. a fix for now is leaning against something where it connects!
Esta resposta foi útil?
Pontuação 0
I took the thing apart and when i turned it on it worked so i put it together and then when i turned it on again it was doing the same thing again.
repeated the steps and instead of the end result a confused look on my face and no light it came on o well!
Pontuação 0
try a new cable or possibly search on youtube
Pontuação 0
1 comentário:
I think it was the supply was weak. needed to let it power cycle
por
Adicionar a sua resposta
Bobby gunnels será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 41
Duração total: 529
