Ir para o conteúdo principal
Bottom microphone not working
So I brought my iphone to authorized repair center to have my lightning port + headphone jack assembly replaced. after a while I noticed that whenever I receive a call the person on another end can’t hear me so I tried voice memo and it won’t pick up any noise unless I shout closely to the bottom of the phone. front facing and back microphone are working fine when I am making video.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like the microphone that the “authorized repair center” installed has failed already. They probably used cheap parts and/or did a sloppy job installing the assembly which resulted in damage to the assembly.
You can replace the assembly with a more quality part at the link below. I also included a guide for you just in case you wanted to DIY.
iPhone 6s Plus Lightning Connector and Headphone Jack
iPhone 6s Plus Lightning Connector and Headphone Jack Replacement
Imagem de Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A.
Produto
$24.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
ronnel jay banay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,231
