My tablet felt the screen is ripped
, now when on it shows time and day and the symbol but it dont react to the touch. do you think its repairable?
Esta é uma boa pergunta?
Hi,
From your description it seems as though the digitizer (touchscreen) is cracked and is no longer working.
Is the display still showing a good picture or is it cracked as well?
If it is only the touchscreen then this can be replaced.
Unfortunately I cannot find a guide or a video online that shows how to replace the digitizer, you may have better luck in finding one
Here’s a link to the ifixit SKYTEX SP1020 Motherboard Replacement guide, which will at least help you to gain access to the display and digitzer.
Here’s a link to just one supplier of the replacement part. It is only shown to give you an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Skytex SP1020 digitizer part to get results.
If this seems all too daunting, contact a reputable, professional electronics or mobile phone repair service and ask for a quote to repair the tablet.
Esta resposta foi útil?
I forgiati torna tell it shped the LOCK symbol
Hoe can I unblok it,?
Hi,
If the touchscreen is broken, you can try to use a USB mouse connected to the micro USB port in the tablet via a OTG adapter cable -example only and use it to swipe the lock and then to navigate through the tablet.
Be aware that the mouse will be powered by the tablet's battery, so it will discharge more quickly than normal.
Also if you can navigate with a mouse change the screen timeout to as long as possible so that you don't always have to swipe to get back into the tablet.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 78
