Toshiba 50L1350UC Tv black screen , sound ok
Screen turns on normally for few seconds then goes black Flashlight shows words images on black screen Audio is normal What should I do next?
Esta pergunta é pertinente?
pharmoron since you are seeing things when you are using a flashlight, it is clear that your backlight is out. This could be an issue related to the power board not providing power to the LED’s; the mainboard not supplying the signal to turn the backlight on (unlikely) or a failed backlight array. Test the LED connector on the power board with a voltmeter (DC voltage) and let us know what values you get.
Toshiba is another black helicopter company that is absolutely paranoid about DIY’ers and of no help at all. We will rely on you to provide images of your boards as well as the voltages etc. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Toshiba mn55L6211U turns on logal comes up turns black red light on
My toshiba tv can't show anything only sound is coming
Yes tv turns black and only sound comes and red dot light show
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 3,341
1 dos comentários
my model number is 49L621U. I jumped the gun and changed out the Video/Main board. I will try a reset and go from there.
por markslot61
