Ir para o conteúdo principal
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
49 Perguntas Visualizar todos
Does my battery need to be replaced? Or is something else going on?
My OP-1 hasn’t kept a charge in over year.
However, up until last week it’s always worked when I plugged it in.
Now it won’t turn on at all.
Is this a battery issue or something else?
Also, while I was previously able to use it when plugged in, it would often give off a constant high pitched hum until I unplugged it and plugged it back in…
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Turned out it was the connector port. Easy solution. Battery was fine.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Daniel Papageorge será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 220
