Print is always too high on page
If I send a job to the printer it always prints too high on the page loosing the top 4mm approx
Esta é uma boa pergunta?
Hi @michaelnm ,
Not quite sure re your printer as it isn’t mentioned in the user guide but check either the printer’s control panel under setup > tools or similar or perhaps in the printer properties menu in the computer whether there is an option to “align the printer” at all.
Most printers have an print alignment test option.
If it has this option see if it resolves the problem for you.
Esta resposta foi útil?
Thank you - I should try the easy options before taking the printer to pieces!
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 2,233
