Ir para o conteúdo principal
The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
20 Perguntas Visualizar todos
turn the headlights on everything goes off on the dashboard
I have a 2004 Nissan maxima when I put the key on the instrument panel lights go on but when I turn the headlights on everything goes off on the dashboard or could it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @joey1217 ,
With the ignition and headlights turned on have you tried adjusting the instrument brightness control switch to check if you can brighten and dim the dash lights? You didn’t state whether you had or not.
Here are some images taken from the owner manual, that may be of some help.
(click on images to enlarge for better viewing)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Joey1217221 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,592
