Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Multiple drive connections
I want a HDD, a SSD and a ODD on the iMac EMC 2428, is that possible? Where is the spare connector?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
You can add a drive into the 27" model, OWC does this service. The 21.5" has no room inside. Here's how to add eSATA ports: http://www.xlr8yourmac.com/systems/imac_...
Esta resposta foi útil?
Pontuação 4
2 comentários:
OWC has now added upgrade options for the 21.5": http://eshop.macsales.com/shop/turnkey/i...
por
This in fact' 'is'' possible.
There are 3 SATA Data Connections on the motherboard. See image here.
There are also 3 Distinct Power connections on the motherboard shown in the image.
In order to retrofit a SSD into the new 2011 21.5" iMacs, You'll need the following parts:
539-1295 (SSD DATA)
539-1296 (SSD POWER)
And the brackets, which part numbers have not been identified for yet.
See image here for an idea of the fit.
Pontuação 2
Is possible, here's the complete guide:
Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit
Pontuação 1
Adicionar a sua resposta
sam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 2,788
