Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
HDD disk utility first aid failed
Please help to recover data… as I do not have a back up
iMac 27” late 2012 high Sierra
Failed to start with internal HDD
Booted with OS on USB external disk
Ran disk utility first aid to check internal HDD
Results below:
Volume “Macintosh HD”
  • Repairing file system.
  • Volume is already unmounted.
  • Performing fsck_hfs -fy -x /dev/rdisk0s2
  • Checking Journaled HFS Plus volume.
  • Checking extents overflow file.
  • Checking catalog file.
  • The volume Macintosh HD could not be verified completely.
  • File system check exit code is 8.
  • Restoring the original state found as unmounted.
  • File system verify or repair failed.
Volume “Govind's”
  • Volume was successfully unmounted.
  • Performing fsck_hfs -fy -x /dev/rdisk0s4
  • Invalid index key
  • Missing thread record (id = 519201)
  • Incorrect block count for file 2018.09.18.G80.asl
  • (It should be 85 instead of 79)
  • The volume Govind's could not be verified completely.
  • Restoring the original state found as mounted.
  • Problem -69842 occurred while restoring the original mount state.
  • Operation failed…
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Did this happen after a system update or upgrade? Are you running the original hard drive?
por
To add to @mayer 's Q's Is this a Fusion Drive config or two independent drives internally?
Is Macintosh HD your Boot drive or is Govind?
por
it happened after it failed to start and I switched on/off a few times. i ran OS on an external drive and checked the internal drive using disk utility.
Macintosh HD was the boot drive. not since it is corrupt it is not booting.
Govind and Macintosh HD are volumes on the single phydical drive.
por
Adicionar um comentário
2 respostas
Solução escolhida
It sounds like you’re disk has got physical surface defects. File system repair utilities are of limited use in such cases. Take a look at Advanced Hard Disk Tools in the Restarters Wiki.
Unless you can boot your iMac into Linux and DOS utilities (I don’t know whether that’s possible) you’ll need to take out the hard disk and temporarily attach it to a PC. There are 2 possibilities:
Spinrite can often recover unreadable sectors by doing its own error correction on the aggregate data accumulated from many reads. It’s far more persistent than any OS or the drive’s internal error recovery logic. If it succeeds it’ll remap the sector. If it was a transient error from a physical jolt or a voltage spike during a write and the disk is otherwise in good health, you can continue using it. However, Spinrite costs $89, but you get a lifetime personal licence and a money back guarantee if it disappoints.
If you can boot into Linux of any flavour then ddrescue will clone your hard disc to another. In a first pass it’ll read everything it can and keep a log of any sectors it couldn’t. You can then rerun it as many times as you like and it’ll just retry the sectors it has so far failed to read. This is a good option if you fear your disk is could die completely at any moment, allowing you to recover as much data as possible while you can. After the first run, running Spinrite might well enable it to succeed completely on a second pass.
Or, you could just find a professional data recovery firm. For a 3-figure sum they should be able to get your data back if it’s humanly possible, and should only charge if they succeed.
Esta resposta foi útil?
Pontuação 1
3 comentários:
@pleriche - I don't think we have to go that far. There are some good disk tools under OS-X & MacOS.
Even still if you wanted to gain direct access to the drive you could just connect your system in Target Disk Mode which allows your Mac to look like a external HD to the other system.
But the rub here is both drives internally have failed which is a very, very rare occurrence! I'm wondering if this is a Fusion Drive setup if it is you wouldn't want to mess with it using any other OS tools as that will make it worse!
Then theres the reason the drive failed. Could be a power surge or lightning event.
por
@Dan We'll see whether the OS-X and MacOS tools do he trick. But Spinrite works at the sector level and is completely file system agnostic. It never moves data so can't do any harm. Theoretically you might be able to use Target Disk Mode but you'd need to run Spinrite under a FreeDOS with a Firewire driver, if there is such a thing. Getting busy with a screwdriver and pulling the drive(s) sounds like more fun to me!
por
I hear you ;-}
I have a system setup with SpinRite just for this reason. It's my last tool when everything else fails.
In this case no FireWire on the 2012 onwards iMacs, only Thunderbolt. Haven't tried running it under Thunderbolt yet and if thats even possible.
FYI: SpinRite 7 will run straight up on a Mac system under BootCamp! Steve keeps telling me it's coming soon!
por
At this point I think you’ll need to use a more powerful tool like Drive Genius to fix your HDD or SSD.
I would recommend you not create partitions on your drive. While I know this can be helpful to segragate files it makes space management harder and often wasteful!
I would encourage you to think about adding a second drive I’m assuming you have a HDD presently. Your system does have the blade SSD connector so you could add it. Do keep in mind this is a big job but it will offer better performance!
Pontuação 1
Adicionar a sua resposta
agswamy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 12,308
