Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
Half of screen black after internal SSD installation.
Half of my screen is black after installing a 1TB SanDisk SSD. The back lights are on, so it’s not that. I’ve heard there are many other people where this problem exists.
Many different theories and ideas…. ie. fans, erase Fusion Drive (which I did erase)
Any suggestions?
BTW, it reverted to OSX 10.6.6 - I WAS on 10.13.6 could that be an issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly, its none of these ideas!
In the process of opening your system you damaged the display assembly. What happened and you’re not the first! Is using the wrong tools as well as the technique to remove the display. Most of the time people dig too far with the tools and use a tool which cuts into the fine wires that make up the grid (X-Y) wires that drive the LCD which are along the edge of the displays glass surface. The other is prying the display up which can stress it. If you release the adhesive correctly the picks and cards is all you need to lift it up enough to then with a light touch lift with your hands far enough up to disconnect the cables. I could even use my pinky fingers to do this just to put into scale the amount of force needed here when its done correctly.
Review this IFIXIT guide: Substituição da tela do iMac Intel 27" EMC 2546 and you need to use the correct tools:
And you do need to replace the adhesive strips
  • [produto vinculado ausente ou desativado: IF174-005-2] - I would get two sets.
At this point you’ll need to buy a new display assembly here’s one source: iMac 27" LCD Display Panel & Front Glass Assembly (12/13)
Imagem de Plastic Cards
Produto
Plastic Cards
$2.99
Imagem de iFixit Opening Picks (Set of 6)
Produto
Imagem de iMac Opening Wheel
Produto
iMac Opening Wheel
$7.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
No,
I used these techniques to open it. Same tools.
Anybody else have an answer?
por
Sorry guy bad display no matter what.
You stated the backlight is working so then it's the driver logic which is part of the screen as well. More often it's the damage to the display during removal, if your driver was dyeing you should have seen some artifacts on the screen before you took the system apart. But then again you could have just been unlucky the extra pressure on the screen taking it off caused it to fail.
por
Adicionar a sua resposta
Bryan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 52
