When I take a picture my picture is a white screen
Hi,
When I take a photo on my 70d canon camera, it’s just a white screen. It’s not the display as I can look at old photos on camera. I have tried a different lens. I have re formatted the SD card. I have tried without flash. Does anyone have an suggestions before I send away?
thanks!
Update (10/02/2018)
this is the image I see (regardless if SD is in or not)
Update (10/02/2018)
it is no longer there. Just a normal menu screen. I thought I had left the battery out, though I will try that for two days this time!
Esta é uma boa pergunta?
5 comentários
Hi @emilysmith , have you fixed your problem? If so then how much does it cost? I also have the same problem
por Al Jadid
Hello, please have you fixed the problem? I have the same issue.
por Bulus Emmanuel
I am about to tear down a 70D with this "Image Snow" issue and will report back with some more detail once I'm in and diagnosed the problem.
por Gavin
Everything I take a picture it is just a white screen
por anabel sosa
I am also facing the same problem videos and picture are white. Showing Err70
por SANTOSH THAKARE
