Ir para o conteúdo principal
Third generation Surface Pro tablet, released June 20, 2014.
123 Perguntas Visualizar todos
New LCD not working?
I have a Surface Pro 3 that had a shattered display. I replace the LCD assembly but it doesn't light up. I know the display, cable and shim/bridge are good because they work in another Pro 3. The display driver is the same as the one in the working Pro 3 and the unit is detecting the LCD because it shows in "Display Settings" when I plug into an HDMI monitor. IOW, it shows two monitors and the digitizer is working. Is there anything else I can try?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Try shining a torch at an angle close to the screen to check if you can detect an image at all when the laptop is turned on. It will be very faint so perhaps try it in a darkened room as it might be easier to see if anything is there.
If you can see an image you've got a backlight problem. Since you say that the new screen and screen cable are OK it must be back on the motherboard.
I don't know how it works in your laptop but on a lot there is a magnet in the lid, below the screen that operates a magnetic switch in the case to turn off the backlight when the lid is closed.
On some, newer Asus models for one, the switch is incorporated on the same board that holds the Power button. It sends a signal to the BIOS to turn the backlight power on and off when the lid is opened/closed.
Not saying that this is the same in your laptop but check for any other cables connected to the motherboard around the Power button area perhaps which may be loose etc
I assume that the GPU still works because you say “…the unit is detecting the LCD because it shows in "Display Settings" when I plug into an HDMI monitor. “ and you’re getting a display on the external monitor OK. Is this correct?
Esta resposta foi útil?
Pontuação 3
2 comentários:
It is a backlight problem because the image is there when shinning a light on the screen. But there is no lid to close on a Surface Pro 3.
por
Hi,
You may wish to contact @botenredwolf and ask if he has an answer as he was working on a similar problem
No LCD Backlight after repair.
Worth a shot ;-)
por
Adicionar a sua resposta
Lew Murray será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 387
