Ir para o conteúdo principal
Repair and service information for the Lenovo IdeaPad 305. Released in 2015, the Lenovo IdeaPad 305 line consists of 3 bright colors and Dolby Advanced Audio.
4 Perguntas Visualizar todos
My laptop sometimes runs slowly and sometimes runs smoothly.
My laptop sometimes runs slowly and sometimes runs smoothly. I hear a noisy sound sometimes when I am gaming and I use a mount for the laptop that has a fan.
What might be the problem? I know it is not RAM cause I have 8GB RAM.
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
1 Resposta
Solução escolhida
Hi,
If the laptop is “noisy” when you are gaming perhaps the laptop may be overheating slightly and the fan is struggling to cope on high speed.
Can you feel the air coming out of the laptop’s fan vent?
Is the laptop’s fan vent clean and unobstructed?
Here’s a link to the section in the service manual which describes the necessary pre-requisite steps and then the procedure to access the heat sink and fan so that you can check. You can also check if the fan is OK.
Also, perhaps the thermal paste applied to the CPU may have dried out and it is no longer as effective as it used to be in helping to transfer the heat away from the CPU, (aided by the heat sink and fan), and it needs to be refreshed.
Search online for how to do this.
If your laptop is running progressively slower and the hard drive activity LED is blinking constantly, use this Lenovo IdeaPad U530 Touch is Running Progressively Slower problem page for possible causes and solutions.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Homer Miraflor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 146
