Ir para o conteúdo principal
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
83 Perguntas Visualizar todos
While im on youtube or netflix...
the video or movie keeps freezing (pausing) on its own or will pick out the next video on its own. what could be causing this and how do I make it stop? it has been dropped on the floor for the 2 foot tall coffee table.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Prior to dropping the game pad was it doing this behavior you mentioned? If not, something might be broken inside the game pad which would probably be the Digitizer.
Update (09/27/2018)
@justlost Here is a replacement LCD and Digitizer screen assembly and a guide on how to replace the LCD and Digitizer. If it turns out that replacing the LCD and Digitizer display assembly does not solve the problem then you can return the LCD and Digitizer display assembly and get your full money back.
Wii U GamePad Screen
Wii U GamePad LCD Display Replacement
Imagem de Wii U GamePad Screen
Produto
$24.99
Esta resposta foi útil?
Pontuação 2
5 comentários:
ok how do I fix that?
por
@justlost You did not answer my question. Was this happening before you dropped your game pad?
por
No it wasnt @ajcooke01
por
Thanks @ajcooke01 i appreciate that
por
@justlost No problem! If this solution worked out for you, go ahead and mark it as correct so we can clean up answers and so that other people know what do do.
por
Adicionar a sua resposta
steven_kurzinger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 96
