My ASUS TP 200S screen wont turn on
My ASUS TP 200S , running windows 10 , new , actually about a month old wont turn on the screen
when i press the power button , the green power indicator turns on but nothing displays on the screen.
What happened before this problem:
the laptop would freeze up while in use and indicate a message that the display adapter driver needs to updated , switching to Microsoft basic display driver
at times i noticed a square box at the middle of the screen during the driver issues
i tried ding a windows 10 upgrade to the latest version available. however , i did not complete the update due to data connection failure after about 13% progress.
i switched it off , and turning it back on has failed since then.
what i have tried :
it has a non-removable battery so i opened the back flip cover , removed the battery and pressed the power button for about 10-15 sec . powered it up , same result.
i then decided to power it up , then check if it is actually on , by inserting a memory card . it plays the plug in sounds , when i plug it on and off , so the system is actually up !
ive checked the screen for any signs of breaking . there’s none.
PLEASE assist .
thanks.
Esta é uma boa pergunta?
2 comentários
hello, thanks for the reply
i have just tried pressing the FN + F7 and F6. it wont turn on
also cant see any faint light on the screen
however, it responds to touch , since its already on. i can touch on the screen and hear clicks , like the folder opening sound etc but its still off
am now going to try connecting to the the external monitor. i have hdmi but the ports are not compatible
por rg whizz
another thing , can the screen be faulty if it already responds to touch ?
por rg whizz
