Ir para o conteúdo principal
O Asus Q534U faz parte da linha de notebooks série Q da ASUSTek Computer Inc. O notebook possui uma dobradiça com rotação de 360 graus que permite alternar entre os modos notebook e tablet com um simples movimento.
How to replace lcd screen
I actually have the asus q524u which I believe is the Best Buy exclusive model? This is the only asus laptop I’ve found with the same hinge/case setup and is probably very similar.
I have some cracks on my lcd screen behind the digitizer. The digitizer glass is perfect and touch works perfect.
I have ordered a new screen that should be here in two days but I can’t seem to find any tutorials on how to disassemble the bezel and screen, I’d hate to have to guess and break clips off or worse.
If anybody has any experience please advise! Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
https://www.youtube.com/watch?v=ynIQwPPD...
It Is not the same exact model in which I understand but it completely the same concept and should help you fine if not give you a great idea on what to do.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, I’ve watched that and many other similar as well. My concern is most of videos I watch there are hidden screws somewhere holding the bezel in place. I don’t see any so I may just pry mine
por Compartilhar
You will be ok man! Good luck
por Compartilhar
Adicionar a sua resposta
cbrackett90 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,734
