Sharp aquos LC-32CHG6021K TV
My Sharp aquos LC-32CHG6021K TV just updated and now everything is upside down how do I flip it back
Esta é uma boa pergunta?
I have the same problem. The Aquos smart TV just updated and the image turned upside. I called the technical support unit of sharp in the UK. Problem solved. Solution: press menu button on the remote; urgently press 1147; select item 7(panel), press item 9(Mirrow). Done. Good luck!
Esta resposta foi útil?
This worked for me thank you so much
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 3,377
10 comentários
Hi @goodhart ,
Did you try the "reset" option found in the TVs "setup" menu? You didn't say.
Be aware if you reset the TV you'll have to scan for the channels again as they will be cleared from the TV.
por jayeff
Did mine 30 mins ago as well same thing happened any luck yet ?
por cjas32
yeah my tv has done the same thing after update,and iv been though every setting this morning and still wont go back to normal
por joe shields
Hi @cjas32,
You may have to contact Sharp about this.
3 different TVs exhibiting the same problem after performing an update is too coincidental to my mind
por jayeff
Sounds like something on their end within the update hence why multiple people have had the problem
por cjas32
Exibir mais 5 comentários
