Ir para o conteúdo principal
Teclado gamer mecânico com clique - Totalmente programável e com 5 teclas macro. Lançado originalmente em 2010.
Slow, delayed key response?
I’ve had my Blackwidow Chroma for a year or two, but only recently I noticed that, in games, the A key isn’t responding to presses in time. It can vary, from about a half-second delay on press, to a full 4 seconds, but it’s definitely there. Does anyone else have issues with this? Is this a common problem with other keyboards? How do I change out the switch if it’s compromised?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I have the same problem but with my D key, has any fix been found for this problem
por
It also happens to me but in the R key and the V key, I have cleaned it up but it stills the same I really dont know why it may be the USB port
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Can you pull keys off? Try pulling it off and see if typing with it off works well. You can also pull another key off from a key you don’t use and put it on the A key spot, doesn’t matter. Then try pressing on it and see if it works.
Esta resposta foi útil?
Pontuação 1
Just turn off the LEDs.
Pontuação 0
It works if you turn of the LED’S as Filipi said. But the problem is the key that was lagging had been assigned as a macro key. Reset that to default and you are good to go. I dont know why this happend or how.
Pontuação 0
I have used static color and it seems to have fixed the problem. I’m not sure how this keyboard is built, but I suppose it’s the keyboard’s controller that has this issue…
Pontuação 0
recently my RAZER Macro keys of Blackwidow (M1~M5 keys) input speed slow down.
(kind window slow problem - they input funtion of M1~M5keys and there are deep delays - keep Ctrl hold kind...)
but i got a hint from these answers.
so i just turn off and back on about CHROMA color fucntion. it's fine now.
thank you guys.
Imagem
Pontuação 0
Adicionar a sua resposta
Daniel Nicolson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 12,596
