Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
425 Perguntas Visualizar todos
Why does my washer stop at rinse cycle?
I have a whirlpool model wtw50000dw1. It will fill and wash but once it gets to the rinse cycle it acts like it wants to go through with the process then lid lock lights up and then rinse light starts blinking. My lid strike looks like it has been cracked-missing a piece off it. Would I need to replace the lid switch and lid Stine and this will solve my problem or is this something else like the actuator switch? Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This can be caused by a failed lid switch or door strike.
https://www.repairclinic.com/PartDetail/...
Esta resposta foi útil?
Pontuação 1
5 comentários:
Purchased the door strike and that wasn’t the problem. Will be purchasing the lid switch now.
por
Can you tell me the one I need to purchase please? Thanks.
por
I wonder if it could be the timer
por
I have same issue. I replaced the door latch, which I have had to do in past, but didn't fix problem. I checked drain hoses too. Nothing
por
Adicionar a sua resposta
Jenni será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 44
Duração total: 1,003
