A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
Esta é uma boa pergunta?
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 79
Duração total: 4,421
