Sony Bravia, LCD screen cracked need to be replaced
Need a replacement of LCD 40 inch Sony Bravia. Need assistance, currently residing in Namibia, Swakop
Esta é uma boa pergunta?
Joey Mupewa replacement panels in general are very hard to come by. If you do then they most often cost more than a new TV. You will have to remove the back from your TV. Take a look at the actual panel. There should be a sticker that has the manufacturer and the exact panel number. Do an online search based on those numbers. It is also possible that you can purchase the same model TV that is broken other than the LCD. Then remove the panel from that.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 839
