I accidently erase the factory and now can bring back the apps
i accidently erase the factory and now can bring back the apps .the android symbol and has a red x. what can i do
Esta é uma boa pergunta?
Hi @angel10914 ,
Try a hard reset using the tablet’s Volume and Power buttons and check if this resolves the problem.
Ensure that the SD Card (if any) is removed from the tablet and that the battery is fully charged before performing a hard reset.
Here’s how to perform a hard reset using the hardware buttons:
Press both Volume Up and Down buttons together along with the Power button, (all 3 buttons together) for about 15 seconds, until you see the Visual Land Prestige logo then release the buttons
Select the option wipe data/factory reset by using the Volume buttons to scroll through the menu and then the Power button to enter and then select yes.
When it states wipe data complete, go back to the top of the menu and select reboot system.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the tablet to its’ factory default condition.
Esta resposta foi útil?
it goes back to the welcome page . not even the settings shows and the apps page nothing
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 81
2 comentários
what can i do
por angel perez
same problem tried everything
por doug
