Ir para o conteúdo principal
Drone quadricóptero fabricado pela GoPro para filmagem aérea.
Crashed Drone, Water Damage
Evening,
Earlier on today I crashed my Karma into a tree which resulted in the props breaking and the drone falling into a stream. The drone was submerged in around 2ft of water for around 15 seconds before I retrieved it. I have removed all broken propellers, GoPro Camera seems okay.
ive removed the battery and tried to dry everything off as best as I can by using cloth and a hair dryer.
im assuming there will be some unseeable water damage, although I am going to give it a few days before I try to turn the drone back on, I was hoping you could give me some insight into what I could do or how much it’d cost me for you guys to look at it and repair and damages?
kins Regards.
Ash
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You can try a food dehydrator to remove all the moisture from the circuit board before you power on again.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ashleachlive será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 17
Ao todo: 601
