Ir para o conteúdo principal
O Dodge Challenger Concept foi apresentado no Salão do Automóvel de Detroit de 2006 e serviu como uma prévia da 4ª geração do Dodge Challenger, cuja produção teve início em 2008. Muitos detalhes de design do Dodge Challenger Concept foram adaptados do Dodge Challenger R/T de 1970.
Tach sitting below zero
just bought a 2010 Challenger R/T last week. I am in the process of installing my radio from my old car into this one. I pulled the instrument cluster to run the microphone wire behind it. Long story short... I went to put it back together and noticed that the gauges were sitting below all the markings. I got everything reset. But now the tach is sitting below zero rpms even when i turn the key on. I have tried resetting the cluster with the trip button. It doesn't help, i manually rest it back to zero with the key on. I turn the key back off and it stays good for about 5 minutes then it falls back below zero and doesn't come back up when i turn the key back on. Need some help on how to get it to sit right. This is the last thing i have left before i can finish putting the car back together.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Did you check all your fuses?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I just seen the date that you posted that. what was the problem?
por Compartilhar
Adicionar a sua resposta
Joshua Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 16
Ao todo: 395
