Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Why a certain website is freezing on loading the page?
I check if the problem is present on a different computer , and from the same router machine. And there is no problem. So the router is not blocked. It must be an IP related blockage. Thank you. Also... I suspected maybe is a special dedicated virus for blocking a website on a specific IP? I scanned my computer with an AV (antivirus) Malwarebytes and nothing is found.
Esta é uma boa pergunta?
Pontuação 1
6 comentários:
is it only one website? or do a bunch of websites not work? if it's only one what is the specific website?
por
hi, its a NSFW type of website and there are a couple of them having the same symptom (loading partially or not at all).
por
Are you using any ad blockers on your browser or anti-virus on computer? They may interfere with the websites and cause issues like that.
por
I found the problem - It was from DNS.
Now, I have further problem. In DNS setting , there are 2 options. If I set the first option : "obtain DNS server address automatically", after some time (not immediately after I close and reopen it) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I read that the last number over 30 it means security for childrens ,etc.
I have click on "Advanced" button in the same window with DNS options, I go to DNS tab, and there I could see and delete the adress. When I delete it from there, in the firts DNS options, automatically switched to "obtain DNS server address automatically".
----------->part1
por
----------->part2
The problem is that, again, after some time (not immediately after I close and reopen all these settings) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I don't know what is triggering the option to switch back. My impression/guess is that is commuted when I access these types of websites. I didn't made the test yet to be certain of the cause.
Please advice, where could be the main trigger?
Thank you!
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Hello nice to meet you, have you tried clearing your browser’s cache and cookies? Sometimes your browser will store old code and try to re-use it when requesting a website you have been to before. Make sure to clear all of the cache, including: history, cookies, and cached images and files. Make sure you clear the whole history and not just the last 7 days. Hope this helps, talk to you soon
Esta resposta foi útil?
Pontuação 0
2 comentários:
It sounds like a background running service or process is monitoring your DNS settings and changing them for you. It could also be a group policy set by the domain server. You have to figure out what is changing your DNS settings by investigating the services you have running.
por
oh, thank you. I will do that.
por
Adicionar a sua resposta
teodoric8 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 279
