Amazon fire stick causes antenna stations to flicker in/out
Signal is strong from antenna but if fire stick power is plugged in the antenna stations will flicker so bad you can’t watch them. It looks like low signal but it’s not.
Esta é uma boa pergunta?
Pontuação
0
Hi @brent511 ,
How close does the antenna cable pass to the Firestick?
Have you tried re-routing the antenna coax lead further away from the Firestick to check if this makes a difference?
Can you make it pass at 90 deg rather than run parallel if it does?
Has it only just started or has it always done this?
por jayeff
6"
Doesn't matter how antenna cable runs
It just started, it only stops when I unplug the ac power on the fire stick.
por Shane Billings
Hi @brent511 ,
Just curious if it also happens if you just switch on the plug pack for the fire stick, without it being connected to the fire stick.
It may be that the plugpack is faulty and emitting too much EMR
por jayeff
Well the problem is gone for now, not sure why. Had firestick unplugged for over a day maybe it performed some sort of reset when I plugged it back in, who knows. Thanks for your interest and suggestions, hope you have good luck in all you do, thanks again.
por Shane Billings
