Ir para o conteúdo principal
A Keurig K55 pode ser identificada pelo seu número de modelo, K55 Classic Series. Lançada em 2 de dezembro de 2015, a K55 é compatível com K-Cups e com café moído tradicional.
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
Esta resposta foi útil?
Pontuação 3
5 comentários:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
por
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
por
Sure will do when I get home from work. Thanks for ur help
por
Hi please find a picture below.
por
Does anyone which power supply I have to buy as in model number etc...
Thanks
por
Imagem
here is the picture
Pontuação 0
Adicionar a sua resposta
Vishal Patel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,140
