Ir para o conteúdo principal
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1696 Perguntas Visualizar todos
Whirlpool Refrigerator does not run unless I slam the door
The refrigerator works intermittently. When ever it stops working i slam the door hard and it will work again until it does the same thing again. I changed the capacitor and the switch. Same thing happens. Any tips or fixes anyone?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
What is the model number of the refrigerator?
What switch did you change?
Slamming the door to make it start, sounds like there is a loose connection somewhere. You may have to be a bit more subtle to find the problem ;-)
por
Adicionar um comentário
2 respostas
Could there be a frayed wire somewhere?
Esta resposta foi útil?
Pontuação 0
Sounds like a loose wire. Wait until it fails then go over the wiring with a multimeter looking for a break in continuity.
Pontuação 0
Adicionar a sua resposta
Razel Lee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 421
