Ir para o conteúdo principal
disabled iPod 3rd generation
im locked out of my ipod 3rd generation. Also it says disabled in red on the top of the device. Can u help me
Esta é uma boa pergunta?
Pontuação 0
1 comentário
This question was migrated from http://meta.ifixit.com/.
por
Adicionar um comentário
1 resposta
Solução escolhida
"Apple says "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." Now there is a way to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" you can also check on here My iPod is frozen says I pod disabled?... Good Luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
america será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 1,014
