Ir para o conteúdo principal
15,6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64 bits, 4 GB de RAM, HDD de 500 GB
Nvidia graphics stop responding
Whenever i install correct nvidia drivers for my laptop it shows an error Nvidia kernel is stop responding and successfully recovered, it shows error in every driver package i install. This problem is occurring a month ago when my laptop controller is damaged so i gave it to dell shop they fix it and since this error is coming bcoz of this camera and sdcard reader is also not working..
Pls help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Only thing that would come to mind for me is the fact that ‘kernel’ is memory associated. However I dug around and found this quoted on another site.
‘Use Run and type regedit
HKEYLOCALMACHINE > SYSTEM > Currentcontrolset > control > graphicsdrivers. Right click graphicsdrivers, click new >Dword (32-bit) value. Modify the value to 8
What I did next was delete ALL of my graphic driver installed (the nvidia one). It will swap to the build-in one on your motherboard.
Then use driver sweeper, select nvidia, and let it erase ALL of your nvidia driver files.
I then re-installed the nvidia driver through the installation CD I got with the graphic card, and did NOT get any updates.’
Esta resposta foi útil?
Pontuação 0
1 comentário:
I tried it but i always shows error "VIDEO TDR FAILURE " and also i tried out the method u show but not workig is my gpu is damaged or something...
por
Adicionar a sua resposta
Pratik Gahane será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 349
