Ir para o conteúdo principal
Repair guides for displays (or monitors) for computers or other devices with video output.
505 Perguntas Visualizar todos
HP desktop display shows for 2 seconds then shuts off
So I have an HP desktop display that comes on for about 2 seconds then seems to dim and lose its connection to the PC showing the display details in what looks to be minimal brightness then shuts down in about the same time frame
I tried many things (known-good cables, different PC, picture does show normally for a few seconds so I don’t think it’s the backlight, tried to change settings but it powers down before I can, etc.) and believe I narrowed it down to the power supply circuit board. I would like a second opinion but that’s what my diagnosis would be. Could anyone else give me some input as to what else I should try before having to change the whole board or the components on the board?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@blaked89
depending on the exact model number, a failed power supply can do this. Check for leaking caps etc. I have seen it where the video board was faulty and turned off the power board, but far less common than a bad power board.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Dang it, I was hoping it was something simple I missed lol
That sounds like the problem to me too, I’ll start testing and see what I can find.
Thanks again.
por
Adicionar a sua resposta
Blaked89 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 628
