Ir para o conteúdo principal
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 Perguntas Visualizar todos
Possible to change the HDMI outlet?
Hi guys,
The micro HDMI on my Transformer book seems to be broken. Its no the lan and its not the screen, I ve tried it by using an other cable and an other screen.
I bought an USB adapter instead to connect it with the screen (HDMI to HDMI). Unfortunately its not fast enough for streaming. So my question is:
Is there a possibilty to change the micro HDMI port, or do I have to change the whole motherboard? If its the second it doesnt make any sence.
Hope to find some help here
Best regards
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
the port could be changed but you would need certain tools to remove the old port and solder the new 1 on
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you for your fast reply, Daniel. Is it complicated to change it, about how long does it take?
por
Just take off the back (I find it easier than my cell back) and crimp the socket gently. I did it with my thumbnail. The metal is pretty soft and easy to bend which is probably why it loosened with multiple use
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 644
