Calculator won't turn on
My TI-84 Plus calculator will not turn on. It is one year old, and seems like new, but won’t turn on. Any suggestions? I can’t find a reset button on it.
Esta é uma boa pergunta?
After trying all other suggestions Just fixed mine, one year old and little use, battery compartment was not making contact with circuit board, unscrewed it and bent the wires that extend from 1st and 4th battery to make contact with copper square and working now.. need T6 bit to unscrew..
Esta resposta foi útil?
Thanks so much for posting! Your suggestion fixed my TI-84 Plus calculator which wouldn’t turn on.
This worked for mine. My 84 SE had been put in storage for years after graduating college. Family needed it so I searched it out of storage to find it wouldn't turn on. After replacing batteries I came here and tried this. It worked. When it came back on it showed ram cleared but still seems to compute just fine. Thank you for this
wire was not making contact this fixed it thanks
A NOTE: When I opened it I could see that the contact wore through the copper, so as you suggested I lined it up on fresh plating but it didn't work.
for anyone who sees this wear but is still struggling:
1) CLEAN the copper and scrub it
2) raise the contacts up towards you so they apply more pressure to the copper plating.
THANK YOU ANDY
My TI is 20 years old, and would not turn on this morning. I feared it was dead. :-( Did as you said, and it is working like new. Thanks!
You should probably refer to this guide. ;)
As for the reset button, there is none on the regular TI 84 Plus. You need to remove one of the AAA batteries, then remove the backup battery. Hold [ON] for 10 seconds then reinsert the batteries. This should clear your RAM. You can also refer to this video Advanced Calculator Recovery, Diagnostics, and Prevention! If you would like a video representation of the guide.
Thank you so much!! I got this calculator from my school and i thought i broke it and had to pay for a new one
it worked!! thank you
You all just saved the day. Popped ours open, adjusted the contacts and it works! Thank you!
I think the length of time can vary quite a bit. For my calculator it was closer to 30 seconds. So, if it doesn't work the first time, try holding the button longer before re-inserting the batteries.
My daughter s TI- 84 Silver Edition won't turn on.
Taking out ALL batteries (including backup) worked for me. YAY!
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 232
Ao todo: 81,576
1 comentário
This worked for me!! Thanks
por Derrick Moore
