Ir para o conteúdo principal
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
Nano sim stuck in sim slot
I accidently inserted a nano sim in the sim slot and now its stuck. How can I get it out without damaging anything.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you are fine with a bit of a hacky solution I have found staples are often quite useful for this sort of thing.
If you have a stapler just staple nothing, collect the staple, and then unbend the prongs into the shape you need. Then just stick it in the slot and wiggle it about to try and lever the SIM card out. I think its unlikely you would damage anything since I don’t think the connections would be very sensitive.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I tried it but I'd didn't work
So I unscrewed anything in my way took everything apart and was finally able to get the sim card out
Thank you for your suggestion
por
Adicionar a sua resposta
Anu Anand será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 399
